Help Changing Sound Profiles.
essenby
Hi,
Please forgive me if this is a simple noobie question - but is there a quick and simple way to change Sound ProfIles? maybe a shortcut or a widget or something. I can't believe that every time I want to move from one profile to another (gooing into a meetiong for example) I have to press:- Menu / Settings / Sound & Display and then select the profile.
There are plenty of widgets/apps on the market for this... otherwise, you can press and hold the power button and a menu will pop up with a few options ;)
If you use the volume controls on the side you can turn it down to 'Silent' and then 'Vibrate'.
This is really a point of contention with me. Got my Incredible Thursday.
I came from a Blackberry and what I need is to be able to change from profiles that have some sounds and some things silent depending on time or location.
It seems Android changes sound inside each program instead of in a central sound location. I really want to find a program that will centralize all the sounds that can be set into profiles and then let me change them automatically. I need the Phone to Ring and SMS to make sound 24 hours a day but I really don't want email or IM to make sounds at night.
Program suggestions?
You've answered your own question - you setup the notifications in the individual apps. There are global settings like ringtone/SMS etc. but for the most part each apps governs itself
Try AudioGuru, it's the best i have found for this so far and i have tried many!!
Also audiomanger can add a widget to your screen for a quick shortcut to liimited sound settings.
