Root Changing splash image problem
Ikenna1
Member
I tried to change my splash image but now when I reboot my phone, the screen is blue where the splash image is supposed to be. I I tried to change it back to the regular lg splash that comes with the phone but it's still blue. Can someone tell me how to change it back to stock.
Sounds like something funny happened during the flash. Blue screen is fastboot (bootloader). While in fastboot you can push recovery again. Then flash your nandroid to get back to your last backup point. Best I got for you. IRC folks can walk you through the process.
You arent getting into fastboot, that blue screen is just what happens when the flash fails or the file is corrupted. If youre using the velocity scripts clear your download cache and try again. Itll work.
It was a wild guess on my part.
I fixed it by reflashing
Guess the problem was that customizing boot is not for 1.0. Anyway I'm on 1.1 again since that app fix was just released.
For the future you can flash this.
Lg_Bootsplash.zip
created by Death2all110
Hope that helps you or others in the future. :D
