I use to be able to add transparency, Change text color for main and middle text. No longer works. Tried clear cache, Permissions and uninstall/reinstall. Is there something else i can do?
Did you try to set a color and then backout immediately.? I had the same problem for a while but now I make a selestion and just hit the back button and the changes apply.
