How do I add new wallpapers to the lock wallpaper screen? I don't want the default ones or the ones in my own personal gallery? Is there a folder I can add them to when my laptop is connected to the phone?
I just connected my phone to my pc, dropped some wallpapers on my sd card under the backgrounds folder (make one if there isn't one there already) and opened that folder when browsing the gallery.
You might have to allow usb debugging in order to connect your phone as a mass storage device (in order to drop the wallpapers on the card). Theres an option under settings->applications>devlopment>usbdebugging.
You might also have to install the samsung android driver for your pc. If you google samsung android driver you should find a link.
