Root Changing the RedPill startup sound
Willister Thanks for all you do! Is there a way to change the Boot SOUND in the red pill ROM? I've tried placing a blank android_audio.mp3 in the system/media dir and also changed wakeup.mp3 with the blank .mp3 but the morpheus audio is still booting, any suggestions?
sure, but i should give you some context.
StaticFilter PM'ed me the question first, so after seeing this, I replied in the PM.
anyway, the path I used for the start up sound is /system/media/audio/ui/Bootsound.mp3 case sensitive. you can disable it by renaming it to Bootsound.bak
