Changing the tones for my sms messages???
Ste20man
Member
Hi.
This is a problem that I hope you guys might be able to help me with.
About a month ago I changed my text message tone from one that I had created myself to a stock one that came with the One S.
I have gone to the settings -> Personalize -> Sound
But I think that I'm doing something right. I want to change back to the older one but no matter how many time I change it won't stick and take. No matter which one I choose.
I change to the sound-set that contains the right info and change the notifications 'message' to the correct tone.
Is there something that I'm missing out on doing?
Would really appreciate your help, cheers, Ste.
Go into your messages. And on the top right corner clock that and go to settings then check your notifications tone from there. Hope that helps
Smokey that worked great man.
You know when you have your phone set up exactly as you like it and just one thing is wrong and it annoys you to hell; this was it.
Thanks again, I'd used this route about 6 months ago and forgot about it. I don't think I would have ever got back there with you mentioning it. Top advice mate, all the best, Ste.
