Help Changing WiFi Password
bertschj
Hello
We use login/pass to connect devices to Cisco WCS Wifi in office. We also expire passwords every 90 days.
Is there a way to just edit/change the device password/account when that time comes? Right now, we have to forget account and add the wifi connection back every time we change.
tx
With the wifi on, go to Settings - Wireless & Networks - Wifi Settings and then touch and hold the Wifi account that you want to change for a couple of seconds. You should get a pop up with options to forget the network and change the password. I hope that helps...
Exactly what I needed - thanks!
Mine says Forget and Modify (but I have leaked ICS)
