charge and OTG at same time
athegn
Android Expert
Is it possible to buy an OTG Cable that allows charging and the use of the attached card reader at the same time?
I have found dual cable devices that aallow charging and OTG but not at the same time. Also cables that alow OTG and supply power to the external device e.g. large hard drive.
Thank you for your reply.
I use OTG on my S2 and Tab 2 all the time; just want to add charging
It looks like that will help a friend with a Hdul.
Since i posted my initial question I have found more information. I have a Galaxy S2 and Tab 2. This site says that they are different from S3 and Note 3 so may not work on them:-
Micro USB Host OTG Y-Cable with Micro USB Power for Samsung Phones | Valarm
Quote "* DOES NOT WORK WITH S2, Note 1, Tab2 or Tab3!!! * " Wrong CPU!!
If anyone has any experience of this cable on the S2 or Tab 2 I would be interested.
