How long should it take to fully charge the battery on theASUS Transformer Pad Infinity TF700T from the battery discharging so low that the tablet automatically powers down (Battery at %1) and after a full charge how long should it run if the display is at about %75 to %80 brightness with super IPS Off GPS on WIFI On Blue Tooth On and The Asus Day Scene Live Wall Paper running? I just bought a ASUS Transformer Pad Infinity TF700T on E-bay and it seems to fully charge the battery to quickely as if it's capacity has gotten low and it only lasts about 5 hours of constantly being on watching videos on Youtube and playing HD video files from the micro SD Memory card surfing the Internet with the stock browser. I had a cheap Chinese Tablet at one time (X10 Airpad XL) and the first one had a bad battery in it and only took 1 hour to fully charge and only lasted less then an hour after a full charge so I was sent a replacement and it took 8 to 9 hours or over night to charge and then would last 8 to 14 hours depending on how I used it. It was only 1024x600 and did not have a very bright screen so it was a lot less of a power hog then a Tablet with a HD Super IPS Screen but still my ASUS Transformer Pad Infinity TF700T should last longer then 5 hours of constant screen on use and should take longer then 4 hours to fully charge from a almost fully discharged battery. ![Frown :( :(](/styles/smilies/google/frown.png)
