Does the plug fit the S3? I know I've used Samsung & Motorola chargers with the wife's S3 when she had problems. They both worked just fine for her phone.
FYI. just because a cable looks the same doesn't mean it has the same internal pins as the stock S3 cable. A lot of times you'll get lucky and actually be able to charge the phone if it fits. Transferring data is a different story. Just because the phone will charge with a cable does not necessarily mean it will transfer data. I've got several cables at my house that look alike. All will charge the phone but only 2 will transfer data.
The iPad cables I've seen will not work at all with the S3.
Dude. Are you talking about the whole assembly (cable & plug)? Or...... are you just referring to the plug? Personally, I've never seen an actual Apple cable that would fit a Samsung device. The plug however is a different story. Plugs that have a USB port can be used with pretty much any device.
