Amazon sells an Anker turbo-charger for about $20. http://www.amazon.com/Anker®-Charger-Qualcomm®-Charge-Technology/dp/B00Q88Q16K
Turbo charging is just a Qualcomm standard that other phones have had since last year.
is the anker charger basically the same as the oem charger?
I use the Turbo charger when testing that requires intense processing and screen use driving the battery down. Otherwise I use the Tylt Vu wireless charger.
The Turbo charger will also charge other phones (like my Maxx).
Charge time on Turbo charger .... 0% to 100% in one hour.
You can use the charger that came with the Maxx to charge the Turbo ... it takes a lot longer.
... Thom
No, it's like a standard charger, usually 1 amp, IIRC.these wireless chargers though don't quick charge the phone do they?
