Charger query
Expecting delivery of a new HTC Sensation soon. Upgrading from a HTC Hero.....for which I own 3 chargers. Will they work on the new Sensation?
Phil
Phil
If the chargers have microUSB plugs, then yes :)
Update: Just had a look, the Hero has a miniUSB socket :(
And I think, the charger's cable is fix engaged on the charger, isn't it?
Note, you shouldn't use a miniUSB-microUSB adapter. Such an adapter might put your Sensation in dock mode.
Harry
The Hero has a charger....and the lead attached to it has USB one side and the other end plugs into the phone. You can use this lead attached to the charger to charge the phone or you can remove the lead from the charger then use this lead for transfering pictures and music and stuff.
Phil
Phil
That are good news :)
You can use the Hero's chargers with the USB cable which will come with your new Sensation.
Harry
There won't any problems with to use them as spare charger for your new Sensation :)
Harry
