Help chargers wont work
When I plug any of my chargers in, it seems like itll charge for a little but then stop. This just started happening and seems like its not connecting properly or its loose on the phone end. Is there a fix?
Chargers go bad easily, so check different Chargers and methods to see if its the phone or charger. When I had my MOTO RAZR I had two Chargers go bad in two years, then after three years the connector on the phone quit working. Since then I've had a few chargers go bad but no more connectors have messed up although I haven't had any other phone as long as the RAZR. You can go to Verizon and get them to check it for you, when I did they gave me a discount on a new charger, its worth a shot to save some $
I had to replace my first X due to a defective usb port. The first clue was when I heard the usb connect/disconnect sounds while plugged into my laptop, and moving the phone.
+1 on the USB plug. They take quite a beating when you push to hard to make sure the cord is plugged in fully then most of us just "jerk" the cord out. This causes the plug to become loose and not charge correctly.
