Charging cable question
jprow507
So I have an old micro USB charging cable (AC and car) from an env2. It plugs into the Incredible but doesn't charge the phone. I would have thought any micro USB charging cable would work. Does anyone know why it wouldn't work?
Thanks for the input ... that is really strange.... the chargers aren't Verizon chargers but they work for the env2 and for a bluetooth headset. When plugged into the Incredible it starts beeping and will show charging then "plug in charger" back and forth....
I wouldn't recommend it. It usually means that it detects a charger, but it is not getting the right voltage or current. So at the risk of possibly frying your new phone, find a charger made for the Incredible or use the stock one.
