Peter123
It is an unfortunate design issue that the charging connector is located on the bottom edge and not on the side.
It is very hard to use the tablet while charging. (can't stand the tablet on the bottom edge while it is plugged in...)
Moreover, the cable from the connector comes out on the bottom side, so if you try to use the table while charging the cable is bent at the connector. This will cause the cable to fail very quickly. This could be remedied with the cable coming out of the connector at 90 degrees.
Anyone saw a connector like that?
ASUS are you listening?
Peter
Peter
