I am have trouble with some of my charging ports. Some fit, some do not. Does the rezound have something different about it? They all worked on my Incredible.
The rezound is compatible. It uses Micro USB which is a fairly universal standard. The port is dual purpose. Make sure you try putting it in correctly.
The rezound only has one port. Flipped one way its Micro HDMI and flipped another its Micro USB.
I was impressed by this dual usage but for a minute i thought it wasn't universal until i flipped the cable over and voila it worked
I had an incredible before this phone as well. If you flip the usb cord over it will fit. Just wiggle it lightly and do not force it in. (Yes I know... "Thats what she said")
