Help Charging current app?
Working for me
(I tweaked the phone to draw 1200mA so that seems right)
Well it obviously shows current on mine lol and funnily enough, other apps show the same current :)
It doesnt show "source" of the current (usb/wall) though but think i can figure that bit out :)
There are two apps called battery monitor widget. Both only show how much mA the phone is using, not what it is pulling from the charger.
Think i found that Elixr 2 was usin up a lot of CPU constantly mate.. i only used it to show me CPU frequency in statusbar and then i used another CPU monitor app to.. monitor CPU and show it in a graph and it seemed to me that Elixr wasnt letting CPU relax down to 200Mhz so it was probably using up more power than it was worth
Depends entirely on what you tell it to do and what items you have as widgets mate :thumb:
If you have a widget to show CPU, then the widget will constantly poll for CPU usage, using the CPU, so constantly reporting back 'some' CPU usage ;) catch 22.
