Help charging issues
is anyone else having problems with charging the arc, mine sometimes seems to "forget" how to charge and wont respond to any charger. rebooting the phone seems to sort the problems
I do have problems with some of my microusb cables, theyre not a tight fit and moving the phone even slightly while charging causes it to stop. Unplugging the cable and then inserting it again usually solves the problem.
The cable that came with the arc seems fine though.
I have exactly same problem, telephone sometime does not charge without restart, I am using original charger. I tried to move cable but didnt help, only phone restart solves this issue. any help?
I have this issue as well. It charges fine when the usb is plugged into my computer but not when its plugged into the wall thingy. I think it's a cable connection issue.
