spooky_b329
My Nexus 4 is a couple of months old but is not coping well with in car charging.
I am using the same two chargers as I did with my old HTC Desire, the Desire would happily sit charging at 1amp (AC) whilst it ran a blackbox recorder app, Dailyroads Voyager. If I wanted it would also cope with streaming spotify and using Google sat nav at the same time. Running these three power hungry apps for an hour would see the phone charge decrease to around 10% but the charger would hold it there and the phone would cope.
With the Nexus 4, it struggles to maintain any real charge when using just Dailyroads, after three to four hours of driving it will be struggling and will normally turn off a few minutes after unplugging. Using Spotify at the same time is pretty hopeless. It normally shows AC but when the battery is going flat it often changes to USB.
Does it detect AC/USB in the same way as the desire? (Shorted data pins) If I get a 2 amp charger can it take advantag of the extra power available or will it limit itself to 1 amp?
On another note, I'm also having trouble with the sat nav regularly dropping out, and it gets pretty laggy, taking a while to catch up when you make a turn.
Thanks for any help!
