Charging LED light
D
Deleted User
Guest
Might light doesn't seem to turn on when it is charging. I have no way of knowing if it is charging or not. Am I the only one?
mine does not either. I have set the led for messages and I have not seen it come on for my messages
Mine works for messages. Just tried sending a text message to my Google Voice account and the light flashes green.
No, mine does not turn on either. The battery indicator on the top right hand of the screen shows a charging symbol but the led does not flash or glow.
The green led will come on solid if the battery is completely charged and it will only blink for notification when the home screen is dim. My question is that I am wondering if there is an application that will control what notifications the led will blink for similar to berrybuz?
Damn! I thought something was broken! Couldn't figure out how to get the green notification led to turn off! Friend of mine was messaging me from gtalk, which makes it flash green, then all the sudden it goes green and stays lit! Was going crazy. (short trip) :D
the green light will STAY on over 90% charge. under it, it will not light up - When the screen is on.
When its off, the light does not stay on, no matter the charge.
