Help Charging Notification Sound won't stop. Help!
New to the android world...
My samsung prevail phone will not stop making that sound when you plug/unplug charger. I tried removing the battery and starting it up again but it's still doing it, and it's draining my battery. Help :/
I would back up any important data then do a factory reset . Turn off phone , hold volume up & camera button and power up the phone , continue to hold vol. up and cam. button . A screen will come up that ask what you want to do ...... scroll down using the vol button to factory reset . Press the camera button to select . Another screen will come up , scroll down to the only one that doesn't say no and press the camera button to select . This will restore your phone back to factory settings . Hope it works for ya ! :D
Thank you!!! Also, can I re-do my google account since I reset the phone? I think when I originally set up my account I must have entered a typo and I cant access the andriod market as it says I have the wrong password. I have been trying to get back into my account and have been working with Google, but they are taking forever.
They only reason you need the same Google account is so you can get access to your contacts , Calender , etc. that Google stores for you . Also , if you have purchased any apps. , they are linked to your original Google account . If you don't need any of this , then make another account . :)
Good luck trying to get this issue resolved, i've tried about everything I can think of and it won't stop!
Anyone out there figure this one out yet??
Thanks
J
Okay, I think I fixed it.. Anyone else want to give this a try to see if it works for them too?
I let my phone COMPLETELY DISCHARGE to the point where it turned itself off, then recharged completely to 100% then removed the charger.. So far it seems to have taken care of the issue.
my phone actually showed that it was charging itself and was making the noise as well. i plugged in my phone and a screen came up asking to choose charger or USB mass storage. i picked charger let it charger for a min then unplugged it and it has not done it again but we will see if it does it again later.
