Help charging phone stops when text comes.
mattcnz
When I recieve a text message while charging the charging stops until I close the pop up for handcent. Does anyone else have this problem or know a fix for it? Thank you.
It doesn't actually stop charging. If you look at the battery emblem the lightning bolt is still there. That was Handcents first attempt at making the light blink even while on the charger. You should be able to go into the setting and edit to no flash or whatever you like.
