Charging phone while using launcher pro
S
Shelbster
Guest
As the title says, I am using Launcher Pro on my Captivate.
When using launcher pro, will I still get a message telling me the phone is fully charged? I have been charging for over 4 hours now, and although my phone says it is at 100% battery, I have not received any messages to disconnect.
I am personally not sure because I switched to adw launcher but I will say that using ADW is still tells me it is fully charged. So unless the new home has to support it which i doubt was done when ADW launcher was created then I would say you should still receive the notification, try doing a battery pull and plug it back in if you haven't done so.
