Help Charging phone WITHOUT battery?
Most phones always run through the battery, so plugging them in without a battery present does nothing.
Electricity will still flow around the phone right? wouldn't that do anything?
I was charging my phone when I took out the battery to see if any things happens and the phone was still On although frozen. Afterwards I unplugged the cable then Turned off.
I've had phones that do have pass through (work without a battery) but very old ones.
Ig yours works then it works but usually the phone's power comes from the battery and the battery charges from the charger, in that order :thumbsupdroid:
I wasn't aware that it worked any other way, how old is a "very old" phone, the kind with a little crank on the side? Lol.
