i seem to have a problem i went to sleep the other night and plugged my phone in to charge and i woke up to find it didnt charge (god knows how it lasted i just hope that battery life will increase during the first week of use??).
Last night i noticed that when i plugged the usb in it didnt show up as charging on my phone, i tried again but the same so this time i thought right ill try a different plug socket this worked.
if i just remove and re-plug into the same socket it doesn't seem to work, nor does unplugging and re-plugging the usb/jac work.
so it seems like i have to unplug from the mains replug it in a different one then put the charger into the phones charge / usb socket to get it to recognise its plugged in to then charge?
surely this cant be normal? all my other phone chargers ive just left plugged into the wall until its needed and plugged it in.
Doesn't seem to have happened since.
UPDATE: HTC suspect its a technical fault with phone or charger, advised to sent back for replacement. will advise if anything changes.
