D
Deleted User
Guest
Not specific to the Droid, but the Droid is all I care about, so here goes...
I know that using a rapid car charger can degrade the battery over time, where the standard wall charger will not.
How about if I have something in the car that allows me to plug the USB cable directly into it, and then that into the lighter? Is that still considered a rapid charge?
How about the USB cable into the computer?
Thanks for any explanations...
