Is there any problem using a charger that has an output of 700mA as opposed to the 1A of the stock evo charger? My thinking is that the 700mA would take longer to charge the evo. Would there be any long term problems?
No problems at all. If it does charge a little slower it's actually better because it will charge it fuller. The only drawback might be a little shorter life on the charger.
Chances are it doesn't even pull the .7A though so I doubt you'll notice a difference.
