I put my phone on to charge last night at 38% and this morning it only showed as 78% after 8 hours charging. I have searched and posted on other posts before about the problems that appear to be linked to the official charger or cable but I was wondering if anyone has seen any official response from Samsung about this as there many posts out there about this.
The phone draws a lot less current when its charging from USB, that can only be changed by rooting and flashing a custom kernel.
Sounds like the wall charger is damaged.
The stock charger is 1200mA and the phone only draws 1000mA by default from it so its more than enough :thumbup:
Have you tried a different cable? I have a similar problem but that's because the cord wore-off, and the kernel reduces the power drawing in until it reached a stable stream, it then reduces it by an additional 100mA. Using my Nexus 7 cable solve the issue completely.
