Help Charging
jcfan4u
When ever my phone IS NOT plugged in this is on the screen and whenever I plug it in sometimes It will charge for a minute then stop help please
jcfan4u;[URL="tel:6247679" said:
6247679[/URL]]package chargers im not sure if it helps to know but it was outside with me for like 3 hrs in 40-50 degree weather
Not sure if that would cause a problem. Did you have this problem before it being outside for 3 hrs in 40-50 degree weather? If not, then most likely isn't the problem. My other guess would be the wall charger, charging cord or the phones charging port is damaged.
Try using another charger and see if it will charge. (If its not another stock charger, it will probably charge very slow since the stock charger is a 2V charger.)
If all else fells, take it back to the place you bought it and have them to try and troubleshoot it.
My phone is clearly more picky after the update. A charger that worked yesterday didn't work last night. The 2A cig adapter I bought only seems to work with the USB cable that comes with the Samsung wall charger. Hopefully someone will figure out what the variable is.
