K
K_M
Guest
When I go on my Data Usage option under settings, it shows me ALL the data I've used through EV & 4G LTE. Is there any possible way to see how much actual 4G LTE I've used this month? :hmpf:
When on the $40 & $50 plan, you can log on to the metro site and under usage in the manage & pay, you will see how much data you have used. It shows you in the form of a meter. I see my friend do this all the time to check.When I go on my Data Usage option under settings, it shows me ALL the data I've used through EV & 4G LTE. Is there any possible way to see how much actual 4G LTE I've used this month? :hmpf:
Or use the mymetro app installed on your phone
Balance & Payments then Data Usage.One more question, where do I go on the MyMetro app to view it?![]()
Thats only counts 4G also
Weird... I don't have that option in myMetro![]()
you have to let the app load
then close it then open it back up
Hmm... I tried that, but I still don't have that option? I even cleared the data, and force stopped the app...
It should have a list:
Yeah, I don't get that option for some reason. I only have 4 options. Not sure why either...
what plan are you on?
I seem to be having the same issue, 50 dollar plan here.
