dirtyriffs
Member
Has anyone noticed any chirping or popping noises during a call? This has happened to me twice now. I dont know if its a defect or part of the low signal issue some people are having.
I'm having the same issue! Do I need to exchange my phone?
You know the popping/staticy sound that a speaker makes if you have an 1/8" connection kind of sitting in there wiggling around as you first plug it in? It's exactly the same as that. Someone had the idea of putting tape under the gap in the camera to fix it... no clue if that worked for them though [Q] Battery cover making a "popping noise" - xda-developers
This issue seems to plague all of Verizon LTE phones. I've seen it on the bug list for the Charge and the Bionic, so it's not just Samsung
