Chomp and Handcent not working properly
harlenm
Either app, almost every message I get a sent failure message, but it actually goes through. People I'm talking to are getting the messages 2-3 times.
Any ideas?
Went back to stock, but the other 2 are so much nicer.
I am swapping this phone for a new one tonight, so I'll try it again with the new phone.
I had used Chomp previously but I prefer some of the additional customization options in Handcent, which have both worked fine for me.
I decided that I would go for.the smallest size and sms pop-up does that. It adds a pop-up with quick reply functionality to the standard messaging app works smooth fast and light
After testing Handcent, I reverted back to the stock app. I had issues sending MMS with Handcent and after reading online it seems a lot of folks do and still use the stock one to send photos/videos.
The stock one is fine, the only thing I really miss is the emoji. But I can get over that :)
You should try sms pop-up if.you like the stock
I use Handcent and haven't experienced any problems with SMS or MMS and I really like it a lot. I used it on my Desire and now on the Inspire. The only thing that still bugs me is that on the Desire, it supports multicolor LED notification and on the Inspire, there is no option in Handcent to change the color of the LED. But anyway, so far - no issues.
