chompSMS question...
WizeGuyDezignz
Android Expert
When forwarding a message in chomp, does anyone know if you can put "Fwd" in front of the message so the person that you are sending it to knows that it's a forward? It seems like I could do this in Handcent (it would ask you before you forwarded it), but I can't seem to figure it out in chomp.
Any help would be appreciated, thanks!
I know this doesn't answer your question, but I've been using Chomp for a long time now, and I'm not sure how to forward! I guess I've never needed to, but now that I look, I'm not finding it on hard press or menu...
To forward in chomp, you just long press on the text bubble of what you want to forward and a menu comes up with "Forward" as one of the options. Hope that helps.
Couldn't you just add the FDW: when you paste the message? I know it's not the answer you're looking for, but it's only 4 characters ;)
You are able to edit the subject line when you forward in Chomp. I usually remove several fwd's before I send since it messes up the subject line.
