Hello,
I'm desperately looking for some help with an issue I'm having with ICS. I upgraded about a week ago to XXLPQ and the phone has been getting more and more reluctant to charge, to the point where it won't charge even if powered off, and nothing draining the battery.
I've a docking station charger and a cable and the wall socket charger supplied, and this is constant with all. The phone think's it's charging as the icon comes up and the connection to a computer allows me to move files.
It got so bad yesterday, that I did a factory reset but this hasn't helped matters.
The only way I can charge is at the moment, the docking station has a port to charge batteries directly without going via the phone. I'm currently using two batteries, one supplied with the phone and a cheapy e-bay one that came with the docking station.
Occassionally when I try and charge the cheap battery with the phone, I get a high voltage warning at about 75%.
If anyone has any advice I would be more than grateful, as it feels like I'm missing a appendage at the moment without it!
James
James
