Help Chrome not compatible with Lucid?
You can get it installed on your lucid but it is really buggy on it I had it on mine and uninstalled after I used it for 2 minutes
how can i update to ics while rooted? i cant seem to do it
You need to use the Verizon Software Update Manager (the phone will install it when you tether it to your computer) to install ICS to a rooted Lucid. This will cause you to lose root, but you can get it back quite easily.
