Root Circle Battery Indicator
Well oh my... No idea whats your even talking about... Maybe i should learn this..
Wish fab would help
here it is
nice work man! looks good! I plan on working on everything this weekend to see what I can come up with. I'd like to get a different battery stuff in there and change the GPS icon. I also want to see if I can find a program that I can take the nextheme signal strengh bars and tint them a blue to match the GPS signal. Or I'm thinking about going green tinted bars with a green GPS icon to keep the "green android guy" colors, plus it will look good with the green letters I have on the nextheme keyboard
Actually yea i think it is the same thing. The app i used allows me to edit the framework on the phone without using a pc. Your using the pc to do it. So yea cool. Im going to have to look into this stuff more to really customize how i want mmmyyyyy phone.
Yeah ninjamorph works well if your replacing one or two things, but when your replacing a bunch (battery images would be like 10 png's for charge and discharge) doing it on the computer is quicker. I used ninjamorph to put the android guy into my status bar drop down but id wanna shoot myself after doing it for a bunch of images lol it would take forever.
Thanks! My weekend is going to filled up with doing this also except Saturday got a football game to go to...hopefully I can get it all done quick enough and post it on here for everyone to try.
In case anyone is interested:
I run into a problem modifying framework-res.apk. You have to do all sorts of things to it if you unzip it before the system will accept it.
To circumvent this, I changed the .apk to a .zip then modified the .zip without extracting it. This seems to maintain the apks sign.
Also, when replacing the battery icons, I noticed that X doesn't use the 10% percentage values eventhough it reports the values in multiples of 10. So adding 10, 30, 50 etc... % pngs has no effect. Anyone know how to fix this?
thats a good hint, thanks!
with the percentage thing, are you using a theme? maybe the theme is only set to report images in values of 20%? like nextheme only has different images in 20% readings I thought I'd read somewhere, so maybe the file telling it what to display is only set to display after a 20% change?
just a thought
No, the DX doesn't have battery icons for the 10% increments. That's my problem. Even though the DX reports in 10% increments, the icons change every 20%.
You have to modify the stats_battery.xml which isa binary file. So convert it to text then mldify it then compile it. I can't seem to get it to work myself, but the premise is sound
yeah thats what I was thinking about those xml files, that they basically told the phone when to display which image. and modifying xml files is way past anything I know how to do lol.
The xml file already has 1% increments listed. Some of the xml files are not readable. When I open them in Notepad++, i don't get actual text.
The stats_battery.xml (I forget exact name) only has them listed every 20%. I converted it to text, so I'm positive.
That is the tool I was using, but I can't seem to get it to work. I grabbed my framework-res, decompiled everything, added the new images(10,30,50,70,90) and modified the xml. Then I recompiled. I tried resigning, as well as just grabbing the images and xml, and stuffing them in the existing framework-res, but I still can't get it to work. Usually my battery indicator is just gone. Worst case is it boot loops, and I have to recover from a backup.
Yup, I'm a newb learning to theme, the hard way.
Wow, my edit didn't make it.
Anyway can someone post step by step directions on how to convert/edit the xml files? I'm pretty much stuck at this point.
Ok, I finally got this all to work, I now have numbers in my taskbar that count down every 10% instead of 20%. It made sense once I started to look at the manifest. You can't just modify the stats_battery.xml since the apk still needs the manifest modified as well, in order to pick up the new images. The easiest guide I found was this one
[Solved!] Changing Notification Application Text Color – FroYo XML Editing | Motorola Droid X
Once you "apktool d" the file, the xml files are just text files.
Thanks aflat.
I noticed that apktool d -f -t fails so I used apktool d -f.
I got some errors about the .9 files. Does this mean anything or can I just rename the files back to how the were?
I didn't get any errors on the decompile, but I know if you do it's probably not a good one to try to compile again.
Hm, i tried on XP and on windows 7 and I get errors with both -f -t switches.
What changes did you make in the manifest file? I don't see anything that needs changing. :confused:
