Accessories class 6 memory card
gurmukhp
Hi there,
I have a class 6 sandisk card in my desire but am wondering if it is actually as fast as it should be. Videos are laggy amongst other things.
I have downloaded a SD card speed test from the market. The results were 13mb/s to write(quite good I thought) but the read speed was only 5mbps/s.
Anyone know if those values are expected?
Thx!
Authoritative read speed ratings are hard to come by. Not even the SDcard organisation lists that information, and googling brings forth a number of different "theoretical" numbers (all of them non-authoritative).
Sorry...
The other day I bought a Kingston Class 4 card. I just came across this thread again, and figured I'd test my card (with SD Card Speed Test), which was rather disappointing!
  • Read: 3Mb/s
  • Write: 2Mb/s
  • Rating: Class 2
Several runs (even with everything else shut down) confirm the result. WTF?! :confused:
There could be many reasons. Is the Kingston card legit? You might be able to check that on their website using the serial number?
It should be legit, I bought the card in a main street store with full packaging. Where do I find the serial number, and do you know where exactly on their site I can check that (or did you simply mean, contact their support)?
I've got a Transcend 8 GB class 6 card which I tested with the app mentioned above: -
Read speed - 12 MB/s
Write speed - 13 MB/s
I wouldn't necessarily trust results from that app though. Try programs such as HD Tune or H2testw.
The lesson here is: buy a Sandisk.
All the shops around here sell unmarked Sandisk items, which on very close inspection are Class 2. I've not seen a single faster Sandisk item. (I prefer a real shop over paying a cheaper price on eBay but then 3x that amount on shipping.)
Good point. Except, the only micro sdcard slot I own is in my Desire. :o I don't suppose mounting it via USB(2) is a very good idea for this type of testing, is it?
Thought: I hope it's not the Desire (hardware/software) that's limiting the card! :confused:
In theory it should be the same all the built in card reader connect internally to the USB bus. So unless the desire is being a bottleneck the results should be very similar.
H2testw v1.4 said:
Warning: Only 5970 of 7327 MByte tested.
Test finished without errors.
You can now delete the test files *.h2w or verify them again.
Writing speed: 2.05 MByte/s
Reading speed: 3.16 MByte/s
All my tests confirm it: My card is not fast enough to earn the Class 4 rating printed on it. I hope the store will take it back. maybe I should (also) contact Kingston directly.
I used the complaint form at Kingston's web site the day before yesterday, and have yet to receive even an acknowledgement. :(
I'm taking the card back to the shop this afternoon.
