DroidJnkie
Just wondering - I
The bootanimation.zip is not needed if you ran the:
dd if=/sdcard/bootanimation.zip of=/system/media/bootanimation.zip
hope that helps
Yeah, that helps. I didn’t know if the “su” commands when you are installing a new notification bar or boot animation transfers it directly to the phone memory, or if every time it boots up it is reading it from the sd card.
So if I were to delete the apk for notification bar, boot animation zip, etc., completely (or back it up to my PC), I'm not harming the phone?
You always run the risk of causing a problem if you remove APKs like that. The only way to tell for sure is to try it and make sure you have a backup plan.
