cashmere_cat
After flashing Roms, changing my mind, installing apps, removing them.... you know all the standard stuff
I seem to have a lot of left over things that don't appear to be needed. Files from apps long since removed, apk files that I had dropped on the SD and then installed.. is it safe to connect to the pc and just delete those items? or is there an app that one should use that finds stray files left behind? I see things from Cyanogenmod even though I've tried about 4 different roms since that one.. Only January, but I think I need to do a spring cleaning on the ole card.
