Accessories Clear case for extended battery
cdtdelta
Hey all,
Does anyone know of a clear case that works with the extended battery? I had the one on the Verizon site but it doesn't really work with the battery now (doesn't seal tight).
I have a silicon on it at the moment at that's ok, but it's still not holding it tight.
I'm looking for a clear one because I have some SkinIt stickers on the phone that I would like to be able to still see (since I paid for the stickers....).
Thanks ahead of time...
I know this is an older thread, but I would be very interested in an answer to this also.
It doesn't matter if it's a silicone or hard case as long as it is really clear and not frosty...
I'm coming up short finding anything that will work with the extended battery (even as small of a change as it is).
I thought the bx6h was 1850mhz. Anyways look at the thread in here for "super thin cases" it will have a link that shows you hard rubberized cases. I have gotten a hard smooth case from ebay that fits just the same as these do. The exact one i got was "skull with wings". I can't guarantee that the regular case not being the hard rubberized case will fit but it did when i got one. But their really cheap so it would be worth a try i think.
