Ok, had my phone less than a week, been researching and have rooted and got s-off.
I want to understand a bit more about how it all works.
1. Putting the PB31IMG.ZIP and doing the update on the hboot screen, this flashes the recovery mode right? Gives us root? Is everything that uses a PB31IMG.ZIP named file on the hboot screen for flashing the recovery? Can you install a rom that way?
2. Whats the difference between installing update.zip and selecting rom from a saved zip file? And is installing the update.zip from the recovery do the same thing as PB31IMG.ZIP?
3. If I want to install a kernal on stock rom, what method would I use? Are all Kernals and ROMs installed the same way? for example, flashing recovery uses PB31IMG, flashing roms uses selecting rom from recovery, and update is for modding pieces of the rom? Or is it all using really the same method of PB31IMG and the options on the recovery screen just do the renaming and rebooting for us?
Thanks for your help.
