I'm working on an android project and created a widget for toggling Bluetooth (i.e., Pressing the widget turn on Bluetooth if turned off and vice versa). But the problem is that click listener of button is not working and when I click on the widget on the home screen it does nothing.
I do a lot of googling and tried almost all solutions but unfortunately nothing worked for me. I am unable to get the idea why my code is not working.
Here is the manifest file for project:
And xml file for widget layout is:
And AppWidget-proviver.xml is:
And BluetoothOnOff.Java Is:
Thanks in advance for your reply and help. I spend a day to resolve the issue but all my effort went in vain
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.gmail.redprince007.togglebluetooth" >
<uses-permission android:name="android.permission.BLUETOOTH_ADMIN"/>
<uses-permission android:name="android.permission.BLUETOOTH"/>
<application
android:allowBackup="true"
android:icon="@mipmap/ic_launcher"
android:label="@string/app_name"
android:theme="@style/AppTheme" >
<receiver android:name=".BluetoothToggle" >
<intent-filter>
<action android:name="android.appwidget.action.APPWIDGET_UPDATE" />
</intent-filter>
<meta-data
android:name="android.appwidget.provider"
android:resource="@xml/bluetooth_toggle_info" />
</receiver>
</application>
</manifest>
Code:
<RelativeLayoutxmlns:android="http://schemas.android.com/apk/res/android"
android:layout_height="match_parent"
android:padding="@dimen/widget_margin">
<Button
android:id="@+id/btnToggleBluetooth"
android:background="@drawable/bluetooth_on"/>
</RelativeLayout>
Code:
<appwidget-providerxmlns:android="http://schemas.android.com/apk/res/android"
android:initialKeyguardLayout="@layout/bluetooth_toggle"
android:initialLayout="@layout/bluetooth_toggle"
android:minHeight="40dp"
android:minWidth="40dp"
android:previewImage="@drawable/ic_bluetooth_icon"
android:updatePeriodMillis="0"
android:widgetCategory="home_screen|keyguard">
</appwidget-provider>
Java:
[code]
publicclassBluetoothToggleextendsAppWidgetProvider{
privatestaticfinalString TAG ="BluetoothToggle";
privatefinalString toggleBluetoothAction ="ToggleBluetooth";
@Override
publicvoid onUpdate(Context context,AppWidgetManager appWidgetManager,int[] appWidgetIds){
Log.d(TAG,"onUpdate()");
// There may be multiple widgets active, so update all of them
finalint N = appWidgetIds.length;
for(int i =0; i < N; i++){
Intent intent =newIntent(BluetoothAdapter.ACTION_REQUEST_ENABLE);
PendingIntent pendingIntent =PendingIntent.getActivity(context, appWidgetIds[i], intent,0);
RemoteViews remoteViews =newRemoteViews(context.getPackageName(), R.layout.bluetooth_toggle);
remoteViews.setOnClickPendingIntent(R.id.btnToggleBluetooth, pendingIntent);
updateAppWidget(context, appWidgetManager, appWidgetIds[i]);
@Override
publicvoid onEnabled(Context context){
Log.d(TAG,"onEnabled()");
// Enter relevant functionality for when the first widget is created
@Override
publicvoid onDisabled(Context context){
Log.d(TAG,"onDisabled()");
// Enter relevant functionality for when the last widget is disabled
staticvoid updateAppWidget(Context context,AppWidgetManager appWidgetManager,int appWidgetId){
Log.d(TAG,"updateAppWidget()");
RemoteViews views =newRemoteViews(context.getPackageName(), R.layout.bluetooth_toggle);
// Instruct the widget manager to update the widget
appWidgetManager.updateAppWidget(appWidgetId, views);
