Help Clicks While Playing Music and Sudden Stops
1st_Paladin
When listening to podcasts, I get a clicking sound and force stop. When I restart the podcast it mostly works fine although there are times it suddenly stops after a few clicks.
Is this a hardware issue?
Me too. Poweramp, music player, radio and deezer all stop playing after 10-15 minutes and every 10-15 minutes afterwards. I wondered if it is deezer messing things up as its the newest app on my phone
This seems to help. I did a soft reset by holding down the Power Button for a few seconds and allowed phone to restart about 5 times. Then did this in the morning. It seems to help. So far no clicks and restarts.
OK guys, this has happened to me. Both using the stock Music player and PowerAmp player. I also noticed when the "clicks" happen the phone screen doesn't light up when pressing the home button. I did as 1st_Paladin says by soft reset, however, the issue returns. This same issue happens when I listen to music while running with my Nike+ app. Anyone seeing a pattern here?
The best advice I can give you guys? Restart your phones daily. Long press home key, and choose Restart NOT Shut Down. Even my ringtones have magically muted! However, after a Restart it returns back to normal volume.
I have a stock ROM as well, and did nothing to my phone.
Can you guys try the RESET before your days starts and confirm if it works best for you?
When I remember, I restart the phone each day. I've noticed that when I forget to do this, this issue seems to return.
Yes, among other issues, I've found out restarting the phone daily works out any problem. This is annoying me to my core, but hopefully any upcoming update will resolve this.
