Clipboard question
james_uk
Hi, I have a question about the clipboard, not sure if this can be controlled in any way. I find that in some apps it works and a lot of the time it does not.
When i do see the list i see things from ages ago in the list and wondered why it doesnt come up all the time when i press in a text field?
Are there any apps that can also make this work if android wont do it in all apps?
thanks
James
thanks for your reply, i will give andclip a try, seems to get good reviews.
do you happen to know what you get in the paid app? on the store it doesn't say, then when i go to the devs website i can't seem to see it there either?
