I sure hope we get something! I'm new to this whole thing and I got the Cliq 2 because of the keyboard and the appearance of the device. I didn't realize how slow and unresponsive it would get! Sometimes when waking the phone I have to try 2 or 3 times to unlock it because the swipe to unlock doesn't register my finger press or it stops halfway and never resets. The touch screen controls just stop responding and then rapidly do a bunch of things I didn't want.
Other times I'll be typing something on the keyboard and find that some of my keys magically activate different functions in my phone instead of typing the key they are supposed to....
This thing is really buggy and I'd like to get away from motoblur as soon as I can. I like the hardware...just needs better firmware.
Does anybody have a factory rom or know how to do nandroid backup this phone? Would be much appreciated!
Have you tried a master reset?
Master Reset - Using Hardware Buttons
To perform a master reset using hardware buttons, following these steps:
Power down the device.
Slide out the keyboard. Press and hold the X key and power button simultaneously.
After approximately 25 seconds, a triangle with a yellow exclamation point (!) will appear along with an android. Press and hold the volume up, volume down and camera buttons for approximately 2 seconds. The Android System Recovery menu will appear.
Use the volume down key to highlight wipe data/factory reset. Press the camera button to select.
Use the volume down key to highlight Yes
Yeah i tried that and it deleted all my settings and apps but this method does not restore the android system files. I.E. The notification bar
Notes:
Please remember always to a Nandroid backup as well as a Application backup. Some MetaMorphs will not be compatibile with your device or ROM please make sure that you always have a way to
This is why I don't recommend people using themes like that.... IMO who cares what what color the notification bar is...... I have heard nothing but problems with metamorph maybe one day I will try it.... if you ever get gingerbread you will get a black notification bar....
Right from droidpirate.com
I did a search on google and I found this
I found that at [Guide] Changing Status Bar/Making your own Metamorph theme - xda-developers
I do apologize if I come off mean I just have an abrasive personality
You have the right to be mean. You know a lot about the android system and are willing to help others. You have already taught me alot xD. So thank you and i will look into the links provided thanks again. PS I agree changing the notification bar was a stupid move on my part...
