Help clock and weather
bikeral
The clock with weather that has always been on my home screen disappeared the other day. Anyone know how to get it back?
You need to add back the widget. I no longer have a TB so I don't remeber the exact steps but I am guessing if you long click on the home screen you will be able to add it if not then application manager will allow it
unfortunately, t is not on another screen or listed on my apps list. I have tried to find it in the play store, but have not been ableto identify it.
It is not an app but it is a widget. It is a HTC widget and I think you get at it from the settings menu but I don't really remeber. I am sure that your phone provider tech support can help you if you can't figure it out or Google HTC widget
Getting old is a bitch...As soon as you said widget, I knew where to find it in Settings/Personalize Thanks to you and Frisco
I am trying add the widget named "Seconds Clock Widget" into my HTC Thunderbolt, but it will not load. I have the ICS update, 1.4 GB of free space, and the widget is only .89MB in size. The Seconds Clock Widget is listed as an app, but it will not come up in Personalize - Widget section.
