Help clock does not auto update?
joesto
hi all
my system tell the dhd to auto update the clock from service provider but only updates if i do a restart of the phone, so is there somthing i have not set?
:confused:
thanks
joe
Sorry that you haven't had an answer yet joesto... I am not sure what to suggest :confused:
Have you always had this problem or is this something that has started to happen recently? If it only started to happen more recently, it may be a case of uninstalling some apps that you have recently installed and installing one by one to see if you can identify which one is causing the problem :confused:
Post back and we will try to help you!! :)
