Root Clock in GB
I have tried many GB rooted ROM's and none seem to show the correct clock time on the homescreen. he time on the top notification bar works but the widget/app...to show date and time on the homescreen does not change/lags...Has anyone had this problem?
Currently I am running LGB V1.3
Thanks
jimmy
This isn't a ROM issue or a GB issue, but an app issue. At this time many apps aren't compatible with Gingerbread, so they don't work properly. This is especially common with clock widgets and many other widgets (the SetCPU widget never refreshes for me). I'd suggest you email the developer and ask that the app be updated to work with Android 2.3.
