clock not correvt on android
dodgepond
how do I get the clock to be correct on my android phone, the acuweather time is correct; but the clock is off by oner hout.
go to settings>date time. you can select auto update (to base it off of whatever tower you are pinging). If it's already set there, and you live close to a timezone border, that may be your issue. it could be pinging off a tower in that timezone. You can also manually set your time.
