Eris_2.1_2010
im stuck here
1: Enter manual download mode by..
- Powering off your phone
- Holding the vol down button while..
- Holding the power button until the Samsung logo appears
- Release both buttons
- You should see a yellow triangle. If you don't, power off and try again.
2: Plug in the USB cable from your PC to your phone
3: Download Odin 1.3
- Unzip it
4: Download ClockWork Mod (non-voodoo) (provided by jt1134)
- Unzip it
5: Execute Odin.exe
6: Press the "PDA" button
- IMPORTANT!! Do not press the "Phone" button!
- Select the cwm_froyo.tar file from the CWM zip file
- Press "Start"
- Wait for your phone to reboot
- Close Odin
7: When your phone boots..
- Enable USB file copying from the drop-down menu
- Copy the update.zip file from the CWM zip to the root of your SD card (the shared drive of your phone)
When I dload cwm it doesnt come as a .zip but as CWMrecovery.tar and i dont get the cwm_froyo.tar either. can someone please help i want my froyo.
- Unzip it
- Unzip it
5: Execute Odin.exe
- Press "Start"
- Close Odin
